I have only recently moved from sickbeard to sonarr and was impressed. Only issue I’m having now is sonar will connect from within my local network but now will no longer connect externally all ports are forwarded correctly as I have been able to connect. All I get now is the sonarr watermark with balls bouncing from side to side but nothing ever appears.
More information running on synolgy DS+415
Version 20150731-8
Tried restart the application a few times with no joy
All DSM up to latest
Same on my iPhone running IOS Beta 9, worked fine till one day I was on a bad wifi network and tried to load the page and it would not load, no luck after that. This is the web clip, using safari works fine.
Okay a little bit more information this hadn’t been working all day I checked the logs the only error I had was signals hearbeat interrupted but I’ve just tried accessing on the off chance and its worked so no wiser but I’m able to access again remotely
