Sonarr version (exact version): 3.0.6.1265-1
Mono version (if Sonarr is not running on Windows):6.12.0.122-1
OS: arch linux
I updated sonarr to the above version, and even after a reboot, ensuring the sonarr service is running, the web page at localhost:8989 isn’t loading. I can’t get into the interface to pull logs.
thanx, here are the most recent entries from the logs after I restarted the sonarr.service:
2021-06-27 13:04:27.8|Info|Bootstrap|Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.6.1265
2021-06-27 13:04:28.1|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
2021-06-27 13:04:28.3|Info|Router|Application mode: Interactive
2021-06-27 13:04:28.5|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2021-06-27 13:04:28.7|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2021-06-27 13:04:28.9|Info|OwinHostController|Listening on the following URLs:
2021-06-27 13:04:28.9|Info|OwinHostController| http://*:8989/
2021-06-27 13:04:29.4|Info|SonarrBootstrapper|Starting Web Server
I don’t see anything odd.
I’m not sure what to look at next. I am happy to provide any information that may help.
–nixit
Trace logs? And is that where they dead end?
thanx for responding!
yes, that is the end of the log at the time, from the looks of the other lines in the logs, sonarr is still running, and checking my subscriptions. it appears that the interface is just not working.
by trace logs, the arch linux system logs, or sonarr trace logs? where do I find those?
–nixit
I have been using the icecat browser for sonarr, and it appears that the web interface no longer loads in the icecat browser.
sounds like a browser issue then no?
what’s the browser dev console say; what is the browser blocking? What do the network calls show?
