Sonarr Not Importing Series from FreeNAS
Sonarr version (exact version): 2.0.0.4562
Mono version (if Sonarr is not running on Windows): N/A
OS: Windows Server 2012 R2
((Debug logs)): https://www.dropbox.com/s/eir10pa8vy3uirq/sonarr.debug.txt?dl=0
Description of issue: I have FreeNAS setup that strictly hosts files, no plugins installed. I then have a server that has Plex/Sonarr installed. The server is setup to download files based on the series within Sonarr to a local 3TB HD, then Sonarr will move these files to my FreeNAS box. The issue is that when I import series’ through Sonarr from my FreeNAS box, it begins to add the series’, however, if I refresh the page no shows/series have been added. Quickly looking through the debug logs, it appears that Sonarr isn’t adding the series as it is matching it against incorrect shows?
Sonarr is able to see the UNC path of my FreeNAS box.
Any assistance regarding this matter would be greatly appreciated.
regards,
chrysis
Have you added them? Your logs don’t show anything being added (but do show the loading of the import page).
You need to click add on the series to add it (the UI only shows the folders that are there until you add them).
