Sonarr not importing episodes from Season packs
I use rTorrent on a remote server. I use Bit Torrent Sync to sync data to a local folder. I have the local and remote paths mapped.
Sonarr will import one episode from the season pack and then stop. This has been happening for a while, I figured I’d wait until this happens several times before reporting. I end up just manually moving the episode files into a drone factory folder and everything gets imported fine.
I am on Sonarr Ver. 2.0.0.3463 develop. I didn’t have debug logging on the last time this happens and it doesn’t look like there is much to go on in the logs from when this last happened. The season pack was grabbed at 9/5 at 3:40pm and the one episode that got imported was at 9/5 4:08pm Here is the log from that time period.
If only one file is synced locally when Sonarr attempts to process the download it will import the only available file and not seeing any others it will assume its done. Remote path mapping would solve this problem as Sonarr would import files by copying them across.
Yea that appears to be what’s happening. So do you mean with remote path mapping I don’t need bt sync and I can just have sonarr copy from a server across the net?
Yeah, you’ll need to mount the remote path to a local folder using something like SSHFS.
Okay. I tried getting SSHFS running on my Synology, but after many different attempts to compile it I gave up. I am still hoping someday a package becomes available for the syno.
