OS: Linux/Unraid Server
Debug logs: https://www.dropbox.com/s/rk81j69uy3st2oj/sonarr.txt?dl=0
I’ve just installed Sonarr for the first time. I’m running it in a docker on my Unraid server. I’m also using Jackett and Deluge as well. I have everything working fine, in terms of downloading episodes of shows but I can’t get Sonarr to copy the file from from the download client folder to the folder where the tv series resides. I’m not sure what I’m missing.
Under settings I have Completed Download Handling enabled.
Deluge does not delete the downloaded files.
When I look at the log file I see
9-10-3 14:01:21.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /data/Completed/Titans.2018.S02E01.Trigon.REPACK.1080p.DCU.WEB-DL.DD5.1.H264-NTb.mkv
The path on the server where the files are download is correct. In the Sonarr docker I have Host Path 4 configured as /mnt/user/appdata/data/Completed/ and I also tried /mnt/user/appdata/data/.
