Sonarr not finding Colbert episodes on BTN
Hi,
Sonarr doesn’t seem to be finding Late Show with Stephen Colbert episodes on BTN. Same thing happened on Sickrage until I added “Stephen Colbert” to Scene Exception under Advanced settings. Is there anyway to make it work?
15-10-28 00:48:24.2|Info|NzbSearchService|Searching 2 indexers for [The Late Show with Stephen Colbert : S01E30]
15-10-28 00:48:24.5|Trace|EventAggregator|Publishing CommandUpdatedEvent
15-10-28 00:48:24.5|Trace|EventAggregator|CommandUpdatedEvent -> CommandModule
15-10-28 00:48:24.5|Trace|EventAggregator|CommandUpdatedEvent <- CommandModule
15-10-28 00:48:24.5|Debug|BroadcastheNet|Downloading Feed http://api.btnapps.net/
15-10-28 00:48:24.5|Trace|HttpClient|Req: [POST] http://api.btnapps.net/
  "jsonrpc": "2.0",
  "method": "getTorrents",
  "params": [
    "<removed>",
      "category": "Episode",
      "name": "S01E30",
      "tvdb": "289574"
    100,
    0
  "id": "88d74893"
15-10-28 00:48:24.5|Trace|HttpClient|Res: [POST] http://api.btnapps.net/ : 200.OK (31 ms)
15-10-28 00:48:24.5|Trace|RateLimitService|Rate Limit triggered, delaying 'api.btnapps.net' for 1.964 sec
15-10-28 00:48:26.5|Trace|HttpClient|Req: [POST] http://api.btnapps.net/
  "jsonrpc": "2.0",
  "params": [
    "<removed>",
      "category": "Season",
      "name": "Season 1",
      "tvdb": "289574"
    100,
    0
  "id": "01c1859d"
15-10-28 00:48:26.6|Trace|HttpClient|Res: [POST] http://api.btnapps.net/ : 200.OK (50 ms)
15-10-28 00:48:26.6|Debug|NzbSearchService|Total of 0 reports were found for [The Late Show with Stephen Colbert : S01E30] from 2 indexers
15-10-28 00:48:26.6|Info|DownloadDecisionMaker|No results found
Oops. I found another thread with same issue The Late Show with Stephen Colbertchanging the series from Standard to Daily seems to have fixed the problem for me.
