Sonarr version: 2.0.0.5338:
Mono version:5.18.0.240:
OS: Raspbian Buster Lite:
Log: https://pastebin.com/CgWTeqPx:
** So I have been trying to setup Sonarr to a private tracker (TorrentSeeds) via Jackett. However every time whether I click automatic search or manual search it says no results found. On Jackett when I manually search I can see the shows I’m trying to watch.All the tests have come back successful and I’ve had success on a public tracker (Nyaa.si) but no dice on the former. I’ve made sure the series type is anime as well as adding too the anime categories.
In the logs I found a repeating error called [Permanent] Unknown Series although I don’t know if that means anything Any help is appreciated. Thanks!**:
