Sonarr not downloading shows well after delay
I download via usenet and if I manually set something to download it works fine, but left to its own devices SONARR won’t download even though I have a 1 minute delay and shows are 7+ hours old.
Does anyone have any idea what setting could be causing this?
Do you have the show set to monitored ?
[URL=http://my.jetscreenshot.com/13737/20160821-cykh-400kb][/URL]
when you manual do a search does it have a “!” icon behind it if so what does it say ?
[URL=http://my.jetscreenshot.com/13737/20160821-espc-46kb][/URL]
A few weeks ago i had a similar issue I notice that almost all my episodes are not downloading automatically. In sonarr I get on the episode column the little clock that says “will begin downloading in 50 minutes” then 50 minutes passes and then I have reset again time and goes to one hour as per settings that the RSS refresh happens. If I click on the override wait time icon the download happens normally. If I click on manually search, I see a bunch of legitimate entries that sonarr could have downloaded.
I solved this by removing the delay from 90 minutes to 0. It could be nice if this is a general bug that can be fixed, I think I have this since the 2.0.0.4230 update. Nothing else has changed on my config.
We’d need to see logs of this, but it’d be best in it’s own thread instead of hijacking another possibly unrelated thread.
I do not thing is totally unrelated as i would never hijack another user’s thread. He has issue with not downloading with the “wait” enable, i have issues like that. Anyway, as i said and try to be helpful to the OP i solve it by removing the wait flag completely
I’m mostly commenting on this part of it. You’re right it’s very similar and not so much hijacking, but not really helpful to us without logs, especially with the OP not providing any logs.
