version 2.0.0.4409
Mono Version
4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 14 12:30:00 UTC 2016)
AppData directory
/home/greg/.config/NzbDrone
Startup directory
/opt/NzbDrone
I am running with ubuntu 16.04
when I goto media management, for instance, the rename thing (first line) has a large ‘|’ and this is true with any choice option on that page (also true with folders, . When I goto season pass all the monitor information has gone away. the little choice boxes (monitored, not monitored, etc) are seriously greyed out. When I goto ‘series’ I get (I used to get a series list):
Title Seasons Profile Network Next Airing Episodes
Continuing (All episodes downloaded)
Ended (All episodes downloaded)
Missing Episodes (Series monitored)
Missing Episodes (Series not monitored)
Series
73
Ended
0
Continuing
73
Monitored
70
Unmonitored
3
Episodes
546
Files
545
Sonarr Ver. 2.0.0.4409
I have stopped the program and restarted it (mono and sytemctl) to no avail, and also rebooted. I would give you my error log but there is nothing there and no warnings either. The regular log shows nothing of interest.
program status:
● sonarr.service - Sonarr Daemon
Loaded: loaded (/lib/systemd/system/sonarr.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2016-12-02 18:03:51 PST; 12min ago
Main PID: 11751 (Main)
CGroup: /system.slice/sonarr.service
└─11751 /usr/bin/mono /opt/NzbDrone/NzbDrone.exe
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] Parser: Release Group parsed: EVO
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] ParsingService: No matching series Suicide Squad
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] Parser: Parsing string 'Suicide.Squad.2016.EXTENDED.1080p.WEB-DL.H264.AC3
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] Parser: Episode Parsed. Suicide Squad - S20E16
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] Parser: Language parsed: English
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] QualityParser: Trying to parse quality for Suicide.Squad.2016.EXTENDED.10
Dec 02 18:14:55 greg-movies mono[11751]: [Debug] Parser: Quality parsed: WEBDL-1080p v1
Dec 02 18:14:56 greg-movies mono[11751]: [Debug] Api: [GET] /api/queue?sort_by=timeleft&order=asc: 200.OK (4 ms)
Dec 02 18:14:56 greg-movies mono[11751]: [Debug] Api: [GET] /api/queue?sort_by=timeleft&order=asc: 200.OK (2 ms)
I have, obviously, no clue on this one.
thank you…
