Example: I just checked an episode of a show (Alienst) Sonarr is monitoring…here is the history:
The following happens automatically:
Sonarr Downloaded SD file…then an hour later
Sonarr Downloaded 720P File
At this point both remain, Sonar does not delete the SD file, however it does state in the history of the episode that it deleted it, with the little trash icon.
A few hours later…
Sonarr downloaded 1080 file, sonarr removed the SD and 720P files.
We’re going to need to see logs that cover the deletion of the SD file and import of the 720p file. I’m not seeing Alienst anywhere in the logs you posted.
The post process is enabled in Sonarr, however Sonarrs history of the file stays as what was originally grabbed, which for example AlienstS01E01.MKV, when the actual file was converted to a MP4.
So the question is, on upgrade from cutoff settings, how do we get Sonarr to realize “hey lets delete lower quality episode, and ignore the file name extension”
If I go in to Sonarr and manually hit the red x on the file, it know it was converted/changed to the MP4 and it deletes it fine. I guess this is because of general scans of the series folders it does, but for some reason that doesn’t hit file history that the cutoff automated deletion uses.
There really isn’t a reason to do that, you’re better off with a delay profile to delay grabbing lower quality releases and let Sonarr see the results as soon as possible with a faster RSS Sync time.
