Running both on the same server, a headless device on my local network. So using “localhost”, , “RPC2” in the setup window
Description of issue: after a fresh reinstall of sonarr, rtorrent is no longer able to connect. I have the same scgi, xmlrpc set up, nothing has changed about it. I have recently updated rtorrent, but sonarr was working with the new version just fine until I reinstalled. Otherwise, sonarr is behaving normally. I also have rutorrent working so there is no problem with the xmlrpc configuration, though chatgpt tells me that’s where the problem lies.
