**Sonarr version (20180303-13)
**Mono version (Synology DSM, DSM 6.0.3-8754 Update 7)
OS:
Hi all, i just updated my DSM and Sonarr, however I won’t start and can not get into the programm itself. Hopefully somebody can help me out
OS:
The log files should tell you more. Default location on synology: /volume1/@appstore/nzbdrone/var/.config/NzbDrone
Config.xml is also located there, you might want to change the log level to debug, clear the logfiles and try to start the package again to get more information.
