Sonarr not automatically grabbing torrents
OS:
Debug logs (posted to hastebin or similar):
Hi there,
Sonarr is not automatically grabbing missing episodes.
If I go into the series menu -> series name -> click magnifying glass icon Sonarr does search for and add the torrents for missing episodes. Most of the time anyway. Sometimes it skips certain episodes. Clicking the manual search icon does show episodes that match the profile I got set.
RSS sync is set to 15, indexers are rarbg and kickass. Going to system -> tasks -> series refresh does refresh series info but doesn’t download missing episodes.
I got series set to “missing” or “all” but in neither case (old) episodes are downloaded automatically.
The two issues are:
  • Episodes are never downloaded automatically
  • Running a manual search (magnifying glass inside series name menu) does download the missing torrents but sometimes episodes are skipped even though a manual search for that episodes shows episodes matching the set profile.
Version 2.0.0.3953
OS windows 10
qbittorent
I can post logs if I know which one is needed to looking over them I don’t see anything going wrong.
ps. I’m new to Sonarr.
Sonarr doesn’t search for old episodes automatically, as explained in the FAQ, it will monitor RSS feeds for old items being reported though.
I think I have the same problem. A new episode is released at night but when I come home I need to click the magnifying class for the download to start. I also have RSS sync set to 15 minutes. Looking at part of the log you can see that Sonarr does search every 15 minutes and then completely stops. There is a 24 hour gap when Sonarr does nothing until I start the search.
16-4-20 16:46:18.2|Info|RssSyncService|Starting RSS Sync
16-4-20 16:46:18.9|Info|DownloadDecisionMaker|Processing 116 releases
16-4-20 16:46:19.6|Info|RssSyncService|RSS Sync Completed. Reports found: 116, Reports grabbed: 0
16-4-20 17:01:48.5|Info|RssSyncService|Starting RSS Sync
16-4-20 17:01:49.3|Info|DownloadDecisionMaker|Processing 117 releases
16-4-20 17:01:49.8|Info|RssSyncService|RSS Sync Completed. Reports found: 117, Reports grabbed: 0
16-4-20 17:17:19.1|Info|RssSyncService|Starting RSS Sync
16-4-20 17:17:19.8|Info|DownloadDecisionMaker|Processing 117 releases
16-4-20 17:17:20.4|Info|RssSyncService|RSS Sync Completed. Reports found: 117, Reports grabbed: 0
16-4-21 19:02:37.6|Info|NzbSearchService|Searching 3 indexers for [The Americans (2013) : S04E06]
16-4-21 19:02:41.6|Warn|NewznabRssParser|Invalid API Key: Membership Expired
16-4-21 19:02:41.7|Warn|Newznab|Invalid API Key for NZBgeek https://api.nzbgeek.info/api?t=tvsearch&cat=5000,5020,5030,5040,5050&extended=1&apikey=(removed)&offset=0&limit=100&tvdbid=261690&rid=30449&season=4&ep=6
16-4-21 19:02:44.2|Info|DownloadDecisionMaker|Processing 12 releases
16-4-21 19:02:48.3|Info|DownloadService|Report sent to ruTorrent. The Americans 2013 S04E06 720p HDTV x264-AVS[rartv]
16-4-21 19:02:48.3|Info|EpisodeSearchService|Episode search completed. 1 reports downloaded.
I’m running Ubuntu with these versions:
16-4-6 18:26:43.4|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.3953
Mono JIT compiler version 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 04:04:55 UTC 2015)
Try updating mono, there is a newer version available.
I recently had to replace my main hard drive and reload everything. Since then my downloads are not happening automatically. If I do a search, I can choose manual or automatic and it works but will not unless I click it. I have the latest version, RSS sync at 15 correct, I use NZB.su and kickass and never had this issue on the old hard drive. I have read all the posts relating to this issue and triple checked my settings but still have to click the search myself to make anything happen and it does start to download immediately. I would like to to be automatic again. Hopefully someone can help
I am running Windows 7 Ultimate 64bit, main drive is 240GB SSD, storage of all downloads on a couple of 2 TB drives, 8gb ram. The only difference from the old drive to this one is I did upgrade it to Windows 10 prior to the hard drive failing, but started using Sonaarr when running Windows 7
Thank you in advance if anyone has anything new to try, it has become quite frustrating when you go work out of town and come back and have to manually download everything
Please open a new thread with logs.
