Sonarr not auto searching missing episodes
Hi
For the past couple of days Sonarr for some reason doesn’t automatically search for missing episodes anymore. I can see them listed in wanted section and I have to go and select search missing and then they will download. Never had a problem before, have restarted and all that and nothings changed.
Here’s a the debug logs for the past 2 days https://www.dropbox.com/home?preview=sonarr.debug.txt
Thanks in advance for any help.
Sonarr doesn’t actually search for missing episodes as explained in the ((FAQ)).
Your logs file link doesn’t work as it’s not a link to the shared file.
We’ll need the following info as well:
OS:
Hi
Sorry about the link, here you go http://pasted.co/7a67ef28
Also Version 2.0.0.4409
16-12-7 07:11:54.0|Warn|Newznab|Request limit reached. A maximum of 10 api hits in a 24 hour interval are allowed for your account. - https://nzb.is/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&tvdbid=264108&rid=35416&tvmazeid=255&season=8&ep=9
I don’t see any RSS Syncs running at all. What is the RSS Sync interval set to on the Indexer settings page (it’s an advanced setting)? 15 is the default.
No RSS Syncing means only manually searching for things would actually find episodes you want.
RSS sync Interval is set to 15. Also Enable RSS sync is set to yes on all the indexers I have listed.
What does System: Tasks show for the last time it ran?
Sorry for the really late reply, here you go http://pastebin.com/AgxXHAFW
Rss Sync 15 minutes in 4 hours in 4 hours
The last execution is in 4 hours which is impossible unless the time has changed, make sure the time if correct on the computer running Sonarr (and the computer you’re connecting from) and restart Sonarr.
