Sonarr not always labelling torrents when grabbed
Sonarr is not always labeling the torrents it grabs, there doesnt seem to be any reasoning why it is or isn’t labeliing torrents.
I have tested both manual and automatic downloading and it remains very inconsistant, when it does label the torrent it imports perfectly
When it doesnt label a torrent, it doesn’t automatically import them to my library when complete
i am running Sonarr 2.0.0.3953 on windows and running qbitorrent 3.3.4
Just to add some more info, the grabed episodes that arent labelled and are downloading, don’t appear in Sonarr;s queue
Hi @jezza1222
I had the same issue in the past. It was due to timeout on my download client side (raspberry).
And these timeouts were due to the non responsiveness of deluge when I was downloading too fast.
1st torrent grabbed, labelled, downloading over 3mb/s
2nd torrent grabbed, not labelled, no push notification, … because the download of the first one totally screw deluge (too fast)
Can you check if this can be the common factor with your issue?
My workaround: set max download speed to 1mo/s on my deluge. I dont need more at all.
Hi.thanks so much for trying to help me out…I will try your workaround but I dont think that’s it as my downloads are never over 1mb a second and sometimes it’s the only torrent downloading…but I will try anyway… Thanks again for your help.
Can you post your logs please?
Hi, I tried to cut and paste the debug log, let me know if I have done the wrong thing. Thanks again for your help
Ok, depug log can be found here
http://pastebin.com/bkw8eQWn
