Sonarr not adding torrents to Deluge
Hi,
I’ve just got Sonarr up and running using some private torrent trackers (with Jacket) and connected to a remote Deluge instance on my seedbox.
The test works fine and it can see Deluge just fine. Even if I manually add a torrent for an episode I need to Deluge directly, Sonarr sees it in the queue and gives me the download status no problem.
The problem I have is that Sonarr is not automatically adding the torrent after a search.
My logs get as far as this after parsing the episode
15-11-15 10:13:43.7|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-720p v1 15-11-15 10:13:43.7|Trace|ConfigService|Using default config value for 'minimumage' defaultValue:'0' 15-11-15 10:13:43.7|Debug|MinimumAgeSpecification|Minimum age is not set. 15-11-15 10:13:43.7|Trace|ConfigService|Using default config value for 'retention' defaultValue:'0' 15-11-15 10:13:43.7|Debug|RetentionSpecification|Checking if report meets retention requirements. 26 15-11-15 10:13:43.7|Debug|DelaySpecification|Ignore delay for searches 15-11-15 10:13:43.7|Debug|HistorySpecification|Skipping history check during search 15-11-15 10:13:43.7|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search 15-11-15 10:13:43.7|Debug|SeriesSpecification|Checking if series matches searched series 15-11-15 10:13:43.7|Debug|DownloadDecisionMaker|Release accepted 15-11-15 10:13:46.3|Warn|DownloadService|Usenet Download client isn't configured yet.
Does anyone have any ideas?
Thanks for any help.
Did you setup a newznab or a torznab indexer? I’m assuming the former since its rejected it because you don’t have a usenet download client.
Ah. Thats the one! My fault completely. Working pretty much perfectly now.
Thanks for the help.
