Sonarr version (exact version): Sonarr version 2.0.0.4326
Mono version (if Sonarr is not running on Windows): Mono 4.4.2
OS: Ubuntu 16.04
((Debug logs)):
(Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) http://pastebin.com/jP6HffGF
Description of issue: Sonarr has worked fine with Transmission-daemon for months now, but in the past week it hasn’t been downloading anything. I did some troubleshooting and found that the connection between transmission and sonarr is failing. On the downloader page it tells me to check the address and port ofr transmission, but they are correct, as is the login/pass.
I can connect to transmission-daemon through a web browser just fine, I can add torrents to it through other means fine as well. And couchpotato connects to it and adds torrents fine too. Any ideas fellas?
Ugh, behind on forum support.
I suppose you’re the guy from reddit
Mono 4.4.x has some known issues, update it to 4.5 at least, or downgrade.
