Sonarr nas problems
Hi there trying to install sonar on a readynas and it gives me this error
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@ReadyNAS:~# seems to be an issue with sonarrs repo - id post on their forums W: Failed to fetch https://apt.sonarr.tv/dists/master/InRelease Unable to find expected entry ‘main/binary-armel/Packages’ in Release file (Wrong sources.list entry or malformed file)
-bash: syntax error near unexpected token `('
root@ReadyNAS:~#
root@ReadyNAS:~# E: Some index files failed to download. They have been ignored, or old ones used instead.
-bash: E:: command not found
root@ReadyNAS:~# root@ReadyNAS:~# seems to be an issue with sonarrs repo - id post on their forums
-bash: root@ReadyNAS:~#: command not found
root@ReadyNAS:~#
We don’t publish an armel package, but you can still get Sonarr running (provided mono 3.10 or later is available), by following the steps for installing on other Linux systems:
