jgourd
June 6, 2017, 11:15am
1
I am running v2.0.0.4753 and several times in recent days I go to access the web GUI and it isn’t running. I go to the Mac Mini and restart it and it works for hours or days. The log shows nothing out of the ordinary, just a gap in time in log entries.
This was running successfully for over a year until this new behavior began. No new software was installed except Radarr which has been running fine for a few months.
Any clue?
Cheers,
Jonathan
We’ll need some more info:
Mono version (if Sonarr is not running on Windows) :
OS :
((Trace logs)) :
The trace logs will need to be from when it’s no longer loading the WebUI.
When it’s not loading the WebUI is the mono process still running? Which could mean that Sonarr is still running, but the WebUI has died.
I experienced the same behavior since a few days. Reverting to the previous update version did not help. I am on Arch (x86) and my mono version is:
mono --version
Mono JIT compiler version 5.0.0 (Stable 5.0.0.100/9667aa6 Fri May 12 07:20:13 UTC 2017)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen (concurrent by default)
My config.xml:
> <Config>
> <LogLevel>Debug</LogLevel>
> <Port>8989</Port>
> <UrlBase>/nzbdrone</UrlBase>
> <BindAddress>*</BindAddress>
> <SslPort>9898</SslPort>
> <EnableSsl>False</EnableSsl>
> <ApiKey>XXXXXXXXXXXXXXXX</ApiKey>
> <AuthenticationMethod>Basic</AuthenticationMethod>
> <Branch>master</Branch>
> <LaunchBrowser>True</LaunchBrowser>
> <SslCertHash></SslCertHash>
> <UpdateMechanism>BuiltIn</UpdateMechanism>
> <UpdateAutomatically>True</UpdateAutomatically>
> </Config>
logs: (with debug enabled, s. above):
17-6-12 12:32:26.0|Info|Bootstrap|Starting Sonarr - /opt/sonarr/NzbDrone.exe - Version 2.0.0.4753
17-6-12 12:32:34.2|Info|MigrationLogger|*** Migrating data source=/home/xxx/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:32:34.8|Info|MigrationLogger|*** Migrating data source=/home/xxx/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:32:35.1|Info|Router|Application mode: Interactive
17-6-12 12:32:35.1|Info|OwinHostController|Listening on the following URLs:
17-6-12 12:32:35.1|Info|OwinHostController| http://:8989/nzbdrone/
17-6-12 12:32:35.1|Info|OwinHostController| http:// :8989/
17-6-12 12:32:35.8|Info|NancyBootstrapper|Starting Web Server
17-6-12 12:33:12.9|Info|RssSyncService|Starting RSS Sync
17-6-12 12:33:13.1|Warn|FetchAndParseRssService|No available indexers. check your configuration.
17-6-12 12:33:13.1|Info|DownloadDecisionMaker|No results found
17-6-12 12:33:13.1|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
17-6-12 12:34:22.5|Info|Bootstrap|Starting Sonarr - /opt/sonarr/NzbDrone.exe - Version 2.0.0.4748
17-6-12 12:34:30.5|Info|MigrationLogger|*** Migrating data source=/home/xxx/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:34:31.1|Info|MigrationLogger|*** Migrating data source=/home/xxxr/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:34:31.5|Info|Router|Application mode: Interactive
17-6-12 12:34:31.5|Info|OwinHostController|Listening on the following URLs:
17-6-12 12:34:31.5|Info|OwinHostController| http://:8989/nzbdrone/
17-6-12 12:34:31.5|Info|OwinHostController| http:// :8989/
17-6-12 12:34:32.1|Info|NancyBootstrapper|Starting Web Server
17-6-12 12:35:03.8|Info|Bootstrap|Starting Sonarr - /opt/sonarr/NzbDrone.exe - Version 2.0.0.4748
17-6-12 12:35:12.4|Info|MigrationLogger|*** Migrating data source=/home/xxxr/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:35:13.0|Info|MigrationLogger|*** Migrating data source=/home/xxx/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-6-12 12:35:13.3|Info|Router|Application mode: Interactive
17-6-12 12:35:13.3|Info|OwinHostController|Listening on the following URLs:
17-6-12 12:35:13.3|Info|OwinHostController| http://:8989/nzbdrone/
17-6-12 12:35:13.3|Info|OwinHostController| http:// :8989/
17-6-12 12:35:14.0|Info|NancyBootstrapper|Starting Web Server
Likely the Mono 5.0.0 issue:
system
Closed
August 11, 2017, 5:48pm
6
