Sonarr version (exact version): 3.0.4.991
Mono version (if Sonarr is not running on Windows): 6.12.0.90
OS: Ubuntu 20.04
Debug logs: Debug log
Description of issue: Sonarr is using torrent name not filename and imports are failing. See screenshots and debug log
Torrent Client: qBittorrent v4.3.0.1 Web UI (64-bit)
Torrent name is:
Bluey.2018.S02E28.Seesaw.720p.ABC.WEB-DL.AAC2.0.x264-[eztv.io].mkv[eztv]
Single file in torrent is named:
Note the [eztv] at the end of the torrent name.
Manual import works fine on the download folder
