Sonarr is searching NZB servers using wrong RID, how do I fix that?
I added the series and it is the correct one (shows right year and description), but the search URL it is using (from the log files) has the wrong RID, so it doesn’t find any episodes. I know the right RID but I’m not sure how to change it.
TIA.
Which tvshow and tvrageid? (and the id you would’ve expected)
I not sure how to find the TVRage ID, but the TVDB ID is 25945 (I assume it is the same) and that works to find the show but Sonarr is using RID=38584. The show is American Crime (2015).
tvrage 38584 is the correct one: http://www.tvrage.com/american-crime-2014
tvrage 25945 (not tvdb) is a 2010 series, cancelled right after the pilot. http://www.tvrage.com/american-crime
We were talking about this show on IRC just 5 hours ago.
The indexer can fix the id for you. Things like that happen regularly.
What do you mean the indexer can fix the ID for me?
Thanks BTW.
The nzb indexer associates release with specific rageids based on some rules. But for this series their automated process picked the wrong one, so that’s something they’ll have to fix. If they got an irc channel, ask it there, otherwise their forum.
