Version
2.0.0.4754
Mono Version
4.8.1
AppData directory
/home/sonarr/.config/NzbDrone
Startup directory
/opt/NzbDrone
Everything is working perfect, except that when Sonarr installs an upgrade, it can’t seem to get the service back up and running. I’m thinking there is a permissions problem somewhere, but I don’t know how to go about fixing it.
My username: nighthawk
Sonarr service runs under sonarr username
** For some reason I have to start the service when in root though. I don’t know how to change that.
Sonarr is installed on /opt with permissions of 755 with ownership of sonarr:xbmc
Any ideas where I should start looking?
EDIT:
It seems the issue is PolKit, but I have no clue how to add a PolKit rule that will allow sonarr.service to start without authentication.
If the service wrapped can restart Sonarr when it detects it has been shutdown that should take care of the restarting automatically, the updater will stop Sonarr and wait for a few seconds, if it’s already been restarted it doesn’t try to start it again, if it hasn’t been restarted the updater will update it.
I have a crontab script that I run every 15 minutes to see if the service is running and if not it is suppose to start the service. But for whatever reason, after an update it won’t restart. It just kills the sonarr.service and then fails to start again.
I can post some logs or something if you tell me what you need. Next time it crashes that is.
