Sonarr is freezing for me about once a day, normally early in the morning. I have to kill the process and re-run for it to fix. I’ve scanned the forums and I see similar complaints, but no fixes.
See here for the log from when I notice the crash. Note, it crashed at 04:31, I came home and saw it had crashed at 22:40. I only have the one saved log at present, if it happens again (which it is likely to do, tonight) I will add that log too.
I’m running on Windows 7, Sonarr is version 2.0.0.3154. It had previously been completely stable, it seems like the instability only started about 3-4 weeks ago. I forget exactly when, unfortunately. Been busy at work.
Trace logs would be a great start, this sounds like another issue I’ve been investigating, but haven’t yet found a cause, but we’re looking for more logs to see what might be causing it.
I’ve been having trouble with this as well. Thankfully I already had trace logging turned on it seems.
Log appears to end at 2:05AM local time and absolutely nothing happens until I try to see whats going on at 23:56 the next night. Webpage doesn’t respond and the NZBDrone windows service wont restart.
Takes a whole server restart to get it back up again.
Yup, that’s the last log file (nzbdrone.log). I can post the .0, .1 etc from the next crash if you’d like. I checked this morning and it’s still running, but I suspect it will die within the next 24 hours. I’ll post the logs as soon as it does. It’s pretty infuriating!
I just pushed a change to develop that should assist in reducing if not eliminating this issue. It will be available in 2.0.0.2306 or higher if one or both of you could switch to it and test it out once its available that would be awesome.
Do you have any steps that might help me exacerbate the problem, so you can properly regress the bug? Otherwise I’ll leave my current build running til it crashes a couple more times, to collect the logs and get an idea of how long it takes.
I’m having the same issue here. Sonarr is locking up and I have to restart the process. Due to this, the program won’t grab anything until it’s been restarted. On a side note, I noticed that if I add a show and there are back episodes, I have to force Sonarr to go out and get them (even if the back episodes are monitored). Either having it do an auto season search or manual search fixes the issue.
One more question…If I am running the Windows version of Sonarr, how do I update the program manually such as when you release a fix for the software program? I went to the Github repository however it looks like nothing is compiled for Windows.
