Sonarr version - 2.0.0.5252
Mono version - 5.10.1.20
OS - Ubuntu - 16.04
**Description of issue: Sonarr appears to be ignoring my quality/size settings on some occasions. One example is with the following HD-720 file… I have it set to limit to 750mb for 1 hour (To grab mostly HEVC), and this works very well most of the time, however, in some cases the 750 limit is being ignored. Here is one example where I’m seeing 1.2gb files downloading, when based on my settings, it should be grabbing the DVD files that are around 600gb. I’ve looked at the length of the episode, and its only 48 minutes, so 1.2 should certainly be out of range… Any ideas what else I should be checking?
