Sonarr version (exact version): 2.0.0.4837 Mono version (if Sonarr is not running on Windows): OS: Windows 8.1 ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Logs Here - https://www.dropbox.com/sh/hx3snep1sxbfsiz/AABkCZZ9ydJBL3FnO7WqALOba?dl=0
Over the last few days Sonarr keeps taking all my CPU power, Ive tried the basics to fix it but to no avail. Also on the System/Logs screen when i try to view the Table all i get is the dots going from side to side, im able to view files and updates, but it just wont let me see tables.
Any help would be greatly appreciated.
Cheers
Thanks for the help, UBlock was causing the issue on the log screen, thanks for that.
Sonarr uses up any cpu that is left over, so anywhere from 30% to 60%
Constantly? I’d expect it to jump up when processing (RSS Sync, items from download client, etc), but otherwise should be close to zero. What do ((trace logs)) show Sonarr doing? (Your short trace log file only shows Sonarr trying to be started a second time).
It seems to have calmed down now since i have turned uBlock off. Which is odd as im sure i have had my system running with UBlock on before. Ill keep an eye on it.
