Sonarr has stopped importing downloads from NZBGet
Sonarr version (exact version): Sonarr Ver. 2.0.0.5252 (develop)
Mono version (if Sonarr is not running on Windows): 5.16.0.151
OS: macOS Mojave 10.14
Debug logs: https://pastebin.com/eTJgZFHt
Description of issue: Recently Sonarr will trigger NZBGet to download files, but will never import them and move them to the correct location after the download has completed. I can manually move the files to the correct location, where Sonarr will happily rename them.
This has been working for years, but has stopped recently.
I haven’t seen any other posting for this error: “[v2.0.0.5252] System.IO.IOException: Win32 IO returned 50. Path: at System.IO.File.Move” - There is nothing after Path in the error.
Looks like this is a bug with mono 5.16, it may also be in previous versions, but I’d suggest downgrading mono.
Downloading -> downgrading? :smile:
Yes, fixed.
Wasn’t able to do anything about this as my Internet went down for a few days. I then saw the v3 pre-release and installed that, and my issues have gone away.
