Sonarr version (exact version): 2.0.0.4753
Mono version (if Sonarr is not running on Windows):4.2.3
OS: ubuntu 16.04
((Debug logs)):17-6-23 06:19:15.9|Error|Owin|SignalR exception thrown by Task: System.AggregateException: One or more errors occurred. —> System.IO.IOException: Write failure —> System.Net.Sockets.SocketException: Connection reset by peer
at System.Net.Sockets.Socket.Send (System.Byte[] buffer, Int32 offset, Int32 size, SocketFlags flags) <0x40f0ecc0 + 0x000e7> in :0
at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) <0x40f0ead0 + 0x000a7> in :0
at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) <0x40f0ead0 + 0x00123> in :0
at System.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) <0x40f0ea20 + 0x0008f> in :0
at System.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) <0x40f7f5a0 + 0x00167> in :0
at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) <0x40f7f500 + 0x00053> in :0
—> (Inner Exception #0) System.IO.IOException: Write failure —> System.Net.Sockets.SocketException: Connection reset by peer
at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) <0x40f7f500 + 0x00053> in :0 <—
_
Description of issue: Sonarr works for a few minutes then the web interface hangs. Killing the task does nothing the only thing that remedies the issue is a reboot.
Just some background: I am using gdrive, rclone /w encryption. Sonarr is pointing to the rclone encrypted mount point. Transmission downloads the torrents and sabnzb the nzbs.
Please let me know what can be done to remedy this issue.
Thansk,
D
