Sonarr doesn't work automatically
Sonarr version (exact version): 3.0.3.774
OS: Windows 10 x64
Debug logs: https://ufile.io/w464uhw9https://mega.nz/file/UkImlAzR#8o3T42_a2wIRFKSNy2ejrhWordwn-M1g7d98spQ2rw8
Description of issue: I don’t remember when, but my sonarr doesn’t download automatically anything! need to check and download new episodes manually
Hello, the errors in your debug file report the following problem everytime the sonarr application tries to query for new files to download. System.Data.SQLite.SQLiteException (0x80004005): database disk image is malformed
This is not very good, it seems your database is corrupted. You will need to do a restore on the DB from a backup, you can follow this guide: Restore I am not sure if you lose any files if you restore but i would imagine so. I’m not sure what the DB contains in sonarr so i will let someone else answer the question of what exactley you will lose.
