Sonarr Doesn't Move Files with Lower Quality?
I often download shows for which I cannot find proper subtitles. Thus, I then need to manually find another version which have a proper subtitle.
For example, I had 1080p version w/o available subtitles. I therefore manually downloaded a 720p version for which there was a subtitle.
However, Sonarr did not move the the 720 version from the download folder because there was already a better 1080p version in the TV folder. The workaround was to first delete the 1080p version.
Is there some way to tell Sonarr to also move the lower quality version from download to TV folder?
You could use manual import or manually delete the lower quality.
There isn’t a way to automate it nor will there be an option to do so as its the same reason why Sonarr doesn’t automatically grab lower quality episodes.
OK. Understand.
