The release that I’m talking about is “Sword Art Online - Alicization - 17 [1080p]”.
It initially seems to respect the Torrent delay but later adds it anyway even though the exact same release exists on NZB. (I tried manually searching the episode in Sonarr withing the 600 minute delay period that I set and It finds it:
Did the NZB fail to download in your client? (Check the history)
If it failed and Failed Download Handling is enabled Sonarr would search for another release, find the torrent and grab that (delays only apply to RSS). If this is the case, set a Minimum Age for NZBs to allow the release to propagate before Sonarr sends it to your client (or do the same in your download client, assuming it supports that).
19-2-4 21:36:28.0|Debug|DownloadDecisionMaker|Processing release '[HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv' from 'HS-1080'
19-2-4 21:36:28.0|Debug|Parser|Parsing string '[HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv'
19-2-4 21:36:28.0|Debug|Parser|Episode Parsed. Tensei Shitara Slime Datta Ken - 018
19-2-4 21:36:28.0|Debug|Parser|Language parsed: English
19-2-4 21:36:28.0|Debug|QualityParser|Trying to parse quality for [HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv
19-2-4 21:36:28.0|Debug|Parser|Quality parsed: HDTV-1080p v1
19-2-4 21:36:28.0|Debug|Parser|Release Group parsed: HorribleSubs
19-2-4 21:36:28.0|Debug|ParsingService|Using absolute episode number 18 for: That Time I Got Reincarnated as a Slime - TVDB: 1x18
19-2-4 21:36:28.0|Debug|AlreadyImportedSpecification|Performing alerady imported check on report
19-2-4 21:36:28.0|Debug|AlreadyImportedSpecification|Skipping already imported check for episode without file
19-2-4 21:36:28.0|Debug|AcceptableSizeSpecification|Beginning size check for: [HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv
19-2-4 21:36:28.0|Debug|AcceptableSizeSpecification|Release has unknown size, skipping size check.
19-2-4 21:36:28.0|Debug|MaximumSizeSpecification|Maximum size is not set.
19-2-4 21:36:28.0|Debug|LanguageSpecification|Checking if report meets language requirements. English
19-2-4 21:36:28.0|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: [HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv
19-2-4 21:36:28.0|Debug|ReleaseRestrictionsSpecification|[[HorribleSubs] Tensei Shitara Slime Datta Ken - 18 [1080p].mkv] No restrictions apply, allowing
19-2-4 21:36:28.0|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-1080p v1
19-2-4 21:36:28.0|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
19-2-4 21:36:28.0|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
19-2-4 21:36:28.0|Debug|DelaySpecification|Waiting for better quality release, There is a 600 minute delay on Torrent
19-2-4 21:36:28.0|Debug|HistorySpecification|Performing history status check on report
19-2-4 21:36:28.1|Debug|HistorySpecification|Checking current status of episode [3264] in history
19-2-4 21:36:28.1|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Temporary] Waiting for better quality release
When it was accepted (I don’t know why it was accepted)
19-2-4 21:36:52.0|Debug|DownloadDecisionMaker|Processing release '[HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]' from 'HS'
19-2-4 21:36:52.0|Debug|Parser|Parsing string '[HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]'
19-2-4 21:36:52.0|Debug|Parser|Episode Parsed. Tensei Shitara Slime Datta Ken - 018
19-2-4 21:36:52.0|Debug|Parser|Language parsed: English
19-2-4 21:36:52.0|Debug|QualityParser|Trying to parse quality for [HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]
19-2-4 21:36:52.0|Debug|Parser|Quality parsed: HDTV-1080p v1
19-2-4 21:36:52.0|Debug|Parser|Release Group parsed: HorribleSubs
19-2-4 21:36:52.0|Debug|ParsingService|Using absolute episode number 18 for: That Time I Got Reincarnated as a Slime - TVDB: 1x18
19-2-4 21:36:52.0|Debug|AlreadyImportedSpecification|Performing alerady imported check on report
19-2-4 21:36:52.0|Debug|AlreadyImportedSpecification|Skipping already imported check for episode without file
19-2-4 21:36:52.0|Debug|AcceptableSizeSpecification|Beginning size check for: [HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]
19-2-4 21:36:52.0|Debug|AcceptableSizeSpecification|Item: [HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p], meets size constraints.
19-2-4 21:36:52.0|Debug|MaximumSizeSpecification|Maximum size is not set.
19-2-4 21:36:52.0|Debug|LanguageSpecification|Checking if report meets language requirements. English
19-2-4 21:36:52.1|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: [HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]
19-2-4 21:36:52.1|Debug|ReleaseRestrictionsSpecification|[[HorribleSubs] Tensei Shitara Slime Datta Ken 18 [1080p]] No restrictions apply, allowing
19-2-4 21:36:52.1|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-1080p v1
19-2-4 21:36:52.1|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
19-2-4 21:36:52.1|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
19-2-4 21:36:52.1|Debug|HistorySpecification|Performing history status check on report
19-2-4 21:36:52.1|Debug|HistorySpecification|Checking current status of episode [3264] in history
19-2-4 21:36:52.1|Debug|DownloadDecisionMaker|Release accepted
Any help at all would be appreciated. Can’t seem to figure this out at all.
Looks like those are from different indexers, so it didn’t grab the same release it originally rejected due to the age, given that my guess the HS indexer is reporting the wrong date/has the wrong timezone.
What does Sonarr show as the Age when grabbed for the grabbed history event?
