Mono version (if Sonarr is not running on Windows):3.2.8 (Debian 3.2.8+dfsg-10)
OS: 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/Linux ( Debian 8)
16-4-16 22:37:33.4|Info|SceneMappingService|Updating Scene mappings
16-4-16 22:37:37.0|Info|RefreshSeriesService|Updating Info for The Hundred Code
16-4-16 22:37:37.1|Info|RefreshEpisodeService|Starting episode info refresh for: [286193][The Hundred Code]
16-4-16 22:37:37.2|Info|RefreshEpisodeService|Finished episode refresh for series: [286193][The Hundred Code].
16-4-16 22:37:37.2|Info|DiskScanService|Scanning disk for The Hundred Code
16-4-16 22:37:37.2|Info|SeriesScannedHandler|[The Hundred Code] was recently added, performing post-add actions
16-4-16 22:37:37.4|Info|MetadataService|Series folder does not exist, skipping metadata creation
16-4-16 22:38:20.9|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
When adding a new serie sonarr does not create the folder for that serie.
Is it possible that this is because that folder is on a NFS mount?
I tried it on the internal disk, but that did not work either.
