Sonarr won’t import it automatically, looking ta things again, isFinished
is one way Sonarr determines the download is complete, but it also uses the status.
A couple key differences in v3:
- Partially imported downloads aren’t treated as fully imported (so one file imported doesn’t show them all as imported and remove them from the queue in Sonarr)
- The status shows downloading over the current quality if it’s still in queue
You have a few options to clean up the queue:
- Put them in a category used by Sonarr (for Transmission that’s a subfolder named to match the category set in Sonarr) then let Sonarr import what it can
- Remove them from the queue in Sonarr, but not transmission (when you click remove in Sonarr you have the option to not remove it from Transmission)
- Put them in a completely different subfolder in transmission, this will cause Sonarr to ignore it (assuming a category is set in Sonarr’s transmission settings)
