Sonarr / Deluge on Synology - Not working
I have Sonarr and Deluge both running on my Synology NAS. I setup Sonarr, however after adding some series, I am not getting deluge to DL anything either. Using iptorrent for the indexer, Synology Deluge for the DL client, tested both via the test button and they succeeded. Any ideas what could be wrong?
[Sonarr - Settings - Indexers]
IPTorrents Enable RSS Sync YES Enable Search NO Feed URL xxxxxxxxx ------ Test passed
[Sonarr - Settings - Download Client] Synology Deluge Host - localhost Port - 8112 URL Base - (blank) PW - deluge category - tv-shows Use SSL - NO --------------- Tested OK
OS:
((Debug logs)):
A screenshot instead of the copy/paste of the UI would be much better.
Sonar Version
2.0.0.4645
Mono Version
4.6.2
Two episodes were suppose to download Sunday, March 12. Upon checking on Monday and today, neither were added to deluge, and not downloaded…
Without ((debug logs)) with the episode you expected to be grabbed on the RSS feed (which would have been when it was posted) it’s impossible to say for certain why it was rejected as there are many reasons.
Does the log that I provided not show March 12 entries on it?
Not sure, I’m not able to open that file (you can save the log file to disk/copy it as a text file).
