Sonarr, Deluge and DelugeSiphon
Hello guys,
I’m trying to find the answer to the following set-up:
I have Sonarr and Deluge on my synology NAS, with Completed Download Handling ON and no Drone Factory enabled.
It works well if I download something from within Sonarr. The label is “sonarr”
The problem is, when I try to send a torrent from outside of sonarr (browsing a tracker and D/L with chrome DelugeSiphon extension), Sonarr does not import or monitors the added torrent, even though it has the same label (I set in deluge label “sonarr” to be auto added for given trackers).
How can I go about to solve this? Do I have to enable also the Drone Factory with a new folder, and give a new label like “TV”?
I would like to avoid if possible drone factory.
Thank you!
Sonarr uses the Label plugin, if you’re using LabelPlus to set the label on the releases grabbed outside of Sonarr it won’t work.
You can check trace logs to see which torrents Sonarr sees (it will likely be JSON or XML).
You’re correct to avoid Drone Factory, especially with seeding torrents.
