after running for half a year without problems on my DS213J Sonarr won’t start up any more. Currently Sonarr isn’t running and everytime I try to run it Mono is producing 100% processor usage for a few seconds. Sonarr is showing that it is running after that, but I can’t access it in my browser. A few seconds later Sonaar powers down again with my Synology reporting the status “stopped”.
The weird thing is that I haven’t changed anything on my synology…
I already reinstalled Sonarr and Mono, after that Sonarr worked for a few minutes but now I got the same problems after I had to do a reboot.
First thing I thought was to check the logs under /usr/local/nzbdrone/var/.config/NzbDrone, but the only log in there is the install.log reporting:
|| Installing package version=“20150731-8” - Fri Jan 15 13:23:50 CET 2016 ||
|| Package Install Completed - Fri Jan 15 13:23:51 CET 2016 ||
I also use the synocommunity version, but I would try the syno one, just to rule it out. As synology uses a a lot of different cpus / architectures there’s no straight forward way of determining what will work on all systems.
There is a way to manually start mono with debug output, but i never managed to get that to work.
Dr_Bean tried to explain it to me once, here was his comment:
So I ended up with this: env PATH=/usr/local/mono/bin:$PATH LD_LIBRARY_PATH=/usr/local/nzbdrone/lib MONO_LOG_LEVEL=debug MONO_LOG_MASK=dll,cfg /usr/local/mono/bin/mono --debug /usr/local/nzbdrone/share/NzbD
rone/NzbDrone.exe
DiskStation> ps | grep nzbdrone
15493 root 3772 S grep nzbdrone
27680 nzbdrone 2376m S N /usr/local/mono/bin/mono --debug /usr/local/nzbdrone/share/Nzb
if you do, kill it
DiskStation> kill 27680
then try and start sonarr again in the synology package manager
