Sonarr Crash/Freezing
Sonarr version (4.0.14.2939):
Mono version (if Sonarr is not running on Windows): I do NOT use docker or containers
OS: MacOS 15.3 Sequoia
Debug logs: Here are logs from the last log generated before I had to restart the program. https://www.dropbox.com/scl/fo/jlw5bp30y8lep5b2a9svf/AHidvzDU7M5BdSQnw2wPAYk?rlkey=sdv869o17qu6xskvr1bp4d31c&dl=0
Description of issue: Sonarr stops being accessible after an unknown amount of time. I cannot access the web interface in any way, using IP or LocalHost. To get working again, you must force quit Sonarr via Activity Monitor, then restart Sonarr.
I have Radarr/Prowlarr/Notifiarr/etc, and do not have this issue with any of those.
