Sonarr version 2.0.0.4949:
Mono version 4.2.3:
OS: Lubuntu
((Debug logs)): https://pastebin.com/Gu7qmjR8
Importing completed downloads from Deluge is failing. Presumed it was a permission issue, but Sonarr is running as root
and has been added to all correct groups (as if it needs it?). System is a Lubuntu running in a Virtualbox, host is also Lubuntu. Files are downloaded to a host shared folder and then to be moved to another shared folder on the host. Deluge running under user deluge
has no issues writing / moving files around. Fresh installs with vanilla configs other than the minimum setup to test.
cat /etc/group | grep root
root:x:0:
vboxsf:x:999:admin,plex,deluge,root
deluge:x:124:admin,root
Was really hoping to solve it on my own with all the other content available here, but it seems I’ve run out of ideas.
