Sonarr constantly using 50% - 60% cpu
****Sonarr version (exact version): Sonarr Ver. 2.0.0.5163
****Mono version (if Sonarr is not running on Windows): 5.12.0.226
OS: QNAP
Debug logs: https://paste.ee/p/iLLid used this site 'cause higher data limit…
Description of issue: Sonarr is constantly using 50% - 60% cpu on my QNAP ts-451… In the resource monitor it shows 2 instances of mono running (most of the time one of them is using all the cpu and the other 0%)
Thanks in advance!
What are the two instances running?
Sonarr only runs under a single instance at a time, this sounds like:
Two instances of mono are running under sonarr… Sonarr isn’t crashing tho, it’s only using alot of CPU…
Right, exactly what the title of that issue is.
Right now it only has one instance of mono running and the usage is back to 2 - 5%… Don’t know how I did it tho…
Would it be better to run it in a container vs using the qpkg? (I’ve heard sonarr is more updated on container)
Would this fix it?
If the qpkg isn’t updated often and you can’t use the built in updater then it may be better. Personally I prefer running it in a docker container and that has been working well for me.
