**Sonarr version 2.0.0.5228
**Mono version (if Sonarr is not running on Windows)n/a
**OS Windows 10
_(I was not aware where the logs are kept or how to enable logging. Sorry)
**Description of issue - Sonarr chose a release that met the profile but had not propagated while there were others of equal quality that were available. I was just wondering if there’s a way to tell it to grab the oldest non-repack version of a program.
I think it’s by design, older releases have more chance of being DMCA’d, so sonarr prefers newer releases if there is a choice. If you have propagation issues on the usenet server you use, you can set a delay profile.
Thanks, that makes sense.
