Sonarr can't read/write 2nd internal volume/harddrive
I’ve installed Sonarr on my Windows 10 setup by the wizard as a service in the default folder. As soon as tried importing my existing TV Shows form my secondary (internal) hard drive i got the message there are no folders on this volume.
Sonarr also can’t add a new TV Shows on this volume, when i select the primary OS SSD drive, Sonarr CAN add folders/import.
When i look in Sonarr’s disk overview it reconnises the secondary (internal) hard drive and shows how many (free) space is left/used.
I think this is a right issue but i don’t know where to look?
Some fact’s:
The secondary hard drive is formated as ExFat, so OS X can also read/write on it.
Other Programs like Couchpotato or uTorrent, can read/write on the secondary drive.
Any errors in the logs?
How is Sonarr running?
Can you write files to the 2nd drive from Windows?
It does sound like a permissions issue, first thing to check is if the user running Sonarr has write access to the drive (The service by default runs as the SYSTEM user).
