Sonarr version (exact version): 2.0.0.4949 Mono version (if Sonarr is not running on Windows): 5.2.0.224 OS: WD My Cloud PR4100 NAS with Docker (containers: linuxserver/sonarr and haugene/transmission-openvpn) Debug log: https://hastebin.com/uzecicusit.rb Description of issue: Everything downloads correctly but I can’t figure out for the life of me how to get Sonarr to be able to import the files.
I am running the containers on a WD My Cloud PR4100 NAS in Docker. Both containers have the same user and group id specified. Also exactly the same mounts for folders. And Transmission uses umask=0
17-10-11 14:57:21.3|Debug|EpisodeFileMovingService|Moving episode file: /CompleteDownloads/series/Family Guy S15E06 - Hot Shots 1080p WEB-DL x265 10bit AAC 5.1 - ImE[UTR]/Family.Guy.S15E06.Hot.Shots.1080p.WEB-DL.x265.10bit.AAC.5.1-ImE[UTR].mkv to /SeriesShare/Family Guy/Season 15/Family Guy - S15E06 - Hot Shots WEBDL-1080p.mkv
17-10-11 14:57:21.3|Debug|DiskTransferService|Move [/CompleteDownloads/series/Family Guy S15E06 - Hot Shots 1080p WEB-DL x265 10bit AAC 5.1 - ImE[UTR]/Family.Guy.S15E06.Hot.Shots.1080p.WEB-DL.x265.10bit.AAC.5.1-ImE[UTR].mkv] > [/SeriesShare/Family Guy/Season 15/Family Guy - S15E06 - Hot Shots WEBDL-1080p.mkv]
17-10-11 14:57:21.3|Warn|ImportApprovedEpisodes|Couldn't import episode /CompleteDownloads/series/Family Guy S15E06 - Hot Shots 1080p WEB-DL x265 10bit AAC 5.1 - ImE[UTR]/Family.Guy.S15E06.Hot.Shots.1080p.WEB-DL.x265.10bit.AAC.5.1-ImE[UTR].mkv
[v2.0.0.4949] System.UnauthorizedAccessException: Access to the path is denied.
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00116] in <77c9551943624fd18301ba6f78a841e5>:0
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, System.Boolean overwrite) [0x000e3] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskProviderBase.cs:222
at NzbDrone.Common.Disk.DiskTransferService.TryMoveFileTransactional (System.String sourcePath, System.String targetPath, System.Int64 originalSize, NzbDrone.Common.Disk.DiskTransferVerificationMode verificationMode) [0x0008f] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskTransferService.cs:489
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, NzbDrone.Common.Disk.DiskTransferVerificationMode verificationMode) [0x003ce] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskTransferService.cs:311
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, System.Boolean verified) [0x0000e] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskTransferService.cs:195
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List`1[T] episodes, System.String destinationFilePath, NzbDrone.Common.Disk.TransferMode mode) [0x0012c] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:118
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0005e] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:80
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, System.Boolean copyOnly) [0x00144] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:66
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List`1[T] decisions, System.Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem, NzbDrone.Core.MediaFiles.EpisodeImport.ImportMode importMode) [0x00277] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:107
Sonarr is unable to access the source or the destination, the fact that Sonarr is able to get this far tells me it has read access to the source file, but may not have write access (if that’s required to create a hardlink) or it can’t write to the destination.
