2.0.0.5228
5.14.0.177
OS:
Linux / Docker
I can´t find Mayan M.C. episodes.
At trackers series is named as “Mayans M.C.” and "Manyans M C "
It´s at request scene mapping file at 9/5/2018 9:34:58 and is added
I refresh task:
Update Scene Mapping 3 hours 8 minutes ago in 3 hours
Query to indexers are only for Mayans%20MC at saids logs:
18-9-13 11:59:24.0|Info|NzbSearchService|Searching 2 indexers for [Mayans M.C. : S01E02] 18-9-13 11:59:24.0|Debug|Torznab|Downloading Feed http://192.168.1.4:9117/api/v2.0/indexers/hdspain/results/torznab/api?t=tvsearch&cat=100004,5040,5050&extended=1&apikey=(removed)&offset=0&limit=100&q=Mayans%20MC&season=1&ep=2 18-9-13 11:59:24.0|Debug|Torznab|Downloading Feed http://192.168.1.4:9117/api/v2.0/indexers/hdcity/results/torznab/api?t=tvsearch&cat=100004,5040,5050&extended=1&apikey=(removed)&offset=0&limit=100&q=Mayans%20MC&season=1&ep=2 18-9-13 11:59:28.4|Debug|Api|[GET] /api/health: 200.OK (5 ms) 18-9-13 11:59:28.4|Debug|Api|[GET] /api/health: 200.OK (2 ms) 18-9-13 11:59:28.6|Debug|Api|[GET] /api/diskspace: 200.OK (214 ms) 18-9-13 11:59:28.8|Debug|Api|[GET] /api/diskspace: 200.OK (141 ms) 18-9-13 11:59:29.4|Debug|NzbSearchService|Total of 0 reports were found for [Mayans M.C. : S01E02] from 2 indexers 18-9-13 11:59:29.4|Info|DownloadDecisionMaker|No results found
It only fails with manual and automatic search.
Scheduled monitoring is working
