Sonarr can not connect to remote server
I’m new to Sonarr. I set it up successfully and have been using it for a few weeks now. Today, I went to manual search and download an episode, but received a red cloud with an ! symbol. Hovering over it shows “Unable to connect to remote server.” When I checked the logs, there were a bunch of failures, DownloadMonitoringService, RestSharpExtensions, etc.
The log file shows this,
Unable to retrieve queue and history items from UTorrent: Unable to connect to the remote server
Exception
System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:8080
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at NzbDrone.Core.Rest.RestSharpExtensions.ValidateResponse(IRestResponse response, IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 33
at NzbDrone.Core.Download.Clients.UTorrent.UTorrentProxy.GetAuthToken(IRestClient client) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\uTorrent\UTorrentProxy.cs:line 228
at NzbDrone.Core.Download.Clients.UTorrent.UTorrentProxy.BuildClient(UTorrentSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\uTorrent\UTorrentProxy.cs:line 254
at NzbDrone.Core.Download.Clients.UTorrent.UTorrentProxy.ProcessRequest(IEnumerable`1 arguments, UTorrentSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\uTorrent\UTorrentProxy.cs:line 174
at NzbDrone.Core.Download.Clients.UTorrent.UTorrentProxy.GetTorrents(UTorrentSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\uTorrent\UTorrentProxy.cs:line 71
at NzbDrone.Core.Download.Clients.UTorrent.UTorrent.GetItems() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\uTorrent\UTorrent.cs:line 80
at NzbDrone.Core.Download.TrackedDownloads.DownloadMonitoringService.ProcessClientDownloads(IDownloadClient downloadClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TrackedDownloads\DownloadMonitoringService.cs:line 86
Is uTorrent using port 8080 for its WebUI?
If not there is a proxy setup that will need to be turned off.
Yeah…
I didn’t have uTorrent open, and yes I have it set to port 8080.
That was a simple fix that I would have stressed over for hours.
Thank you!!
