OS: Windows 10 64bit
Description of issue: I currently don’t fully understand what is happening. I get an external 4 bay SATA enclosure and moved my drives to it. I went through and got Sonarr setup on my laptop. Now, I look inside folders for series that I updated the path via Series Editor and all of the seasons are gone. I lost terabytes of shows.
Sonarr doesn’t move files when you change the path with Series editor. Not sure how the external enclosure works (if you had to format drives to add them or it’s just JBOD). Sonarr won’t start deleting files unless something was misconfigured and Sonarr was told to import new downloads from a series folder or multiple series shared the same folder.
