Sonarr and TV releases such as Japanology Plus
I noticed that Japanology Plus’s release format is either "Japanology Plus - Moving Services (2017.02.02).avi " or " (2014.09.04) Japanology Plus - Taiko Drums (720p 50fps).avi ".
I guess the date is a little off since the release group is not putting the Japanese air date (western date is 1 day behind)
Is there anyway I can do a workaround or can Sonarr also check Series Name / Title and allow us to pick the show via manual search?
Those are named in a way that Sonarr won’t support, I think the only way that would be possible is via, but that’s not a short term goal.
That makes sense. I actually created a specific RSS feed for that show, so any manual process to let Sonarr know the series and episode is very do-able.
Heck, if there was a way to add a file re-name feature in sonarr which allows files dumped in a folder of a show to be manually matched up then re-named, that would be awesome too!
Guess I’ll wait and see if this is implemented in future Sonarr releases! Until then, I guess I will need to manually download and re-name the files. :slight_smile:
You could use manual import from Wanted: Missing to do the importing, still manual, but you can select the series, season, episode and quality and hit import so you can do it from wherever you can access Sonarr.
