Sonarr and Torrent Clients - Magnet issues
Sonarr version (exact version): 2.0.0.4689
Mono version (if Sonarr is not running on Windows): 4.8.1
OS: Linux Mint 18.1 & Raspbian Jessie
((Debug logs)): https://pastebin.com/eA1s1NB2
Hello all!
Working on setting up a Raspberry Pi as my content downloading box… I’ve got it configured to use Deluge as my torrent client and have successfully linked Sonarr (running on a different Linux machine on the same network) with it. Trouble is, when Sonarr sends a magnet link to Deluge, it never gets any peers and never downloads. it just sits with nothing in the tracker status as “downloading.” I’ve tried this with Transmission and they never get past “magnetized transfer.” I’ve also tried it with Transmission on the same computer with the same result. Deluge on the Raspberry Pi works perfectly fine if I manually add torrents, either via .torrent or via copied in magnet link to the web UI. Using Deluge 1.3.10 because that is the Jessie stable version on the Pi.
Sorry for the super cluttered log - Line 365 is one example of where Sonarr has sent the report to Deluge.
Any insight is greatly helpful. Thanks!
Well then, my apologies for opening up an unnecessary topic!
As it turns out, it was an issue specifically with the torrent indexer I was using. I’ve since changed to a different one and magnet links are working like a champ!
Cheers
