Hi,
I have Sonarr setup with NZBGet but I am a bit confused as to the setup.
My current setup is:
NZBGet downloads into /media/usb0/TV/Temp/downloads/tv/
After it is finished it moves download into /media/usb0/TV/
Then sorts and renames into the correct TV show folder
But after the download is finished (I think) Sonarr is trying to import the TV show to check it is finished, but the download has been moved by NZBGet.
So after a TV download is finished I am getting the following error in Sonarr
Import failed, path does not exist or is not accessible by Sonarr: /media/usb0/TV/Temp/downloads/tv/Banshee.S01E05.720p.BluRay.x264-DEMAND
Am I missing something? This path does not exist because it was only temporarily downloaded here
The path TV show is setup in Sonarr as /media/usb0/TV/Banshee/ which is where the finished download is moved to, so I would have thought it would check there instead of the temp download folder?
I appreciate any help! Thank you!
