Sonarr and Deluge
Hi Guys,
I have just started to use Sonarr, I was previously using SickRage but it started to mess up for me.
What I have noticed is that when I use Sonarr to send the files to Deluge I end up with two copies, one in /deluge/completed/ and another in /TV Shows (which I had to set in Sonarr). Is there a way I can set Sonarr to not download the file as well or delete it from the /TV Shows folder after a certain amount of time?
Thanks
Why there are two copies is explained in the FAQ. If seeding limits are reached and Sonarr is set to removed completed downloads it’ll remove them automatically.
Hi Markus,
Thanks for the reply, if seeding limits get reached the files get removed from the Deluge completed folder and not the Sonar TV Shows folder, is it possible for it to do this as I don’t want them to delete before I have even had the chance to download the files to my computer?
Thanks
You could turn off Completed Download Handling, but then Sonarr will treat the file as missing and never completed.
Sonarr doesn’t support not importing the file and treating it as complete or deleting it after some time.
Ah I see, is there anyway for Sonarr to automatically delete the files after a certain amount of time?
How can I turn off Sonarr removing the files from Deluge? Is there a setting for that?
Thanks
No option to auto delete.
Yes there is an option to disable removing from Deluge, Remove Compeleted Downloads, it’s off by default.
Hi Markus,
OK, cool - I will double check it is switched off.
Thanks for you help :+1::slight_smile:
