Sonarr version (exact version): 2.0.0.4689
Mono version (if Sonarr is not running on Windows): 4.8.0
OS: QTS 4.3
((Debug logs)):
17-4-26 19:21:40.3|Info|RssSyncService|Starting RSS Sync
17-4-26 19:21:41.2|Info|DownloadDecisionMaker|Processing 28 releases
17-4-26 19:21:42.1|Warn|ProcessDownloadDecisions|Couldn’t add report to download queue. The Handmaids Tale S01E03 720p WEBRip HEVC X265-RMTeam
[v2.0.0.4689] MonoTorrent.TorrentException: Invalid torrent file specified —> MonoTorrent.BEncoding.BEncodingException: Could not find what value to decode
at MonoTorrent.BEncoding.BEncodedValue.Decode (MonoTorrent.BEncoding.RawReader reader) [0x00090] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\MonoTorrent\BEncoding\IBEncodedValue.cs:146
at MonoTorrent.BEncoding.BEncodedValue.Decode (System.IO.Stream stream) [0x0000e] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\MonoTorrent\BEncoding\IBEncodedValue.cs:99
at MonoTorrent.Torrent.Load (System.IO.Stream stream, System.String path) [0x0000c] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\MonoTorrent\Torrent.cs:705
at MonoTorrent.Torrent.Load (System.IO.Stream stream, System.String path) [0x00027] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\MonoTorrent\Torrent.cs:711
at MonoTorrent.Torrent.Load (System.Byte[] data) [0x0000d] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\MonoTorrent\Torrent.cs:556
at NzbDrone.Core.MediaFiles.TorrentInfo.TorrentFileInfoReader.GetHashFromTorrentFile (System.Byte[] fileContents) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\TorrentInfo\TorrentFileInfoReader.cs:14
at NzbDrone.Core.Download.TorrentClientBase1[TSettings].DownloadFromWebUrl (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode, System.String torrentUrl) [0x0019d] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\TorrentClientBase.cs:180 at NzbDrone.Core.Download.TorrentClientBase
1[TSettings].Download (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x00148] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\TorrentClientBase.cs:117
at NzbDrone.Core.Download.DownloadService.DownloadReport (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x00171] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\DownloadService.cs:66
at NzbDrone.Core.Download.ProcessDownloadDecisions.ProcessDecisions (System.Collections.Generic.List`1[T] decisions) [0x0014e] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\ProcessDownloadDecisions.cs:74
17-4-26 19:21:42.1|Info|RssSyncService|RSS Sync Completed. Reports found: 28, Reports grabbed: 0
I just set up ascript which searches for the latest x265 releases from MagnetDL and generates an RSS feed from them. The RSS works fine, is xml compliant and is tested OK with Sonarr.
However, while it appears that Sonarr finds the release I’m looking for (The Handmaids Tale S01E03 720p WEBRip HEVC X265-RMTeam) it doesn’t add it to Transmission.
My question is: is a .torrent file needed by Sonarr to add tasks to Transmission or is it fine with a magnet link? If the magnet link is taken into account, why doesn’t Sonarr send it to Transmission? The RSS I cooked up just pulls up the magnet link and no .torrent file address, is that the problem?
Lastly, thanks to everyone involved in the Sonarr project!
