Sonarr version (exact version): 2.0.0.4689 Mono version (if Sonarr is not running on Windows): not sure, running on unraid. qBittorrent v3.3.12 OS: unraid 6.3.3 Debug logs:https://pastebin.com/R04ccfT3
I’ll look into having Sonarr produce a more sensible warning and handle the situation gracefully instead of thinking that adding the torrent failed. But you should check your qbit settings.
its weird because it shows as succeeded under the sonarr settings https://i.imgur.com/2edJoEI.png so im not sure what else to do. the mappings under unraid docker is fine and my radarr setup hasn’t had any problems (using qbittorrent as well).
